365IT
Jan 03, 2020Aspirant
VLAN MAPPING on M4300
Hi
We must implement too M4300 stacked in a existing network and we need to map a particular VLAN in an OTHER.
Explanantion :
A existing VLAN20 cannot be changed in all others swtiches.
We need this VLAN to be MAPPED on an other VLAN like VLAN 5050, all unntag or tagged ports.
thanks for your reply.
- DaneANETGEAR Employee Retired
Welcome to the community! :)
It would be best if you post a detailed diagram of your current network setup and the network setup you want to achieve. In this way, community members would know what to suggest to your query.
DaneA
NETGEAR Community Team
Voila:
M4300 VLAN 20 Untagged Port/LAG <---> Port/LAG Untagged VLAN 5050 on the other switch.
- 365ITAspirant
Yes, this will be working with untag frames.
But will not functiun with tagged frames.
You shoud implement this :
