Drakecoldwinter
Aug 14, 2024Tutor
VLAN Routing Help
I have an old FSM726v3 switch. I would like to create 2 Vlans, one for my computers vlan1 (192.168.1.x) and another vlan200 (192.168.200.x) for a couple of crypto miners. I defined both vlans and did...
ErwinL
Sep 05, 2024NETGEAR Moderator
Hello PDAHazzard
And welcome to the NETGEAR Community! 🙂
You may want to check the link below for Inter VLAN routing.
https://www.downloads.netgear.com/files/7000_Web_UM.pdf
Have a lovely day,
Erwin
Netgear Team
PDAHazzard
Sep 10, 2024Aspirant
Dank Erwin!
Is there -by any change- more recent (beta-) firmware available?
I connect to the gui with a mac. The java embeds are not working, Neither are the non-java frames. Is there something to do about that?
And is there somehow something to tweak on the fans? They are blowing full force constantly what seems to be a bit overdone...
Best regards,
Martin
Apeldoorn
- ErwinLSep 16, 2024NETGEAR Moderator
Hello PDAHazzard
We apologize, but the FSM726v3 switch is an older model, and firmware updates are no longer available for it. If you're having trouble accessing the UI with your Mac, could you try using a Windows machine? Regarding the fans, unfortunately, there is no option to modify their performance.
Have a lovely day,
Erwin
Netgear Team - ErwinLJan 07, 2025NETGEAR Moderator
Hello PDAHazzard,
I have not heard any update from you. Please let us know if are still having issues with accessing the UI with that setup?
Have a lovely day,
Erwin
Netgear Team
