jgraczyk
Dec 27, 2012Aspirant
VLAN Routing Problem
I have a simple network set up with a GSM7328S (V2, I think) and a GS724T. I have a 4 line lag between them and a few vlans that appear in both switches. The lag between the switches has all vlans ta...
jmizoguchi
Jan 13, 2013Virtuoso
Forum is use to user base! Don't expect you will get swift answer at your will.
If you need immediate assistant ,use portal to contact support at my.netgear.com
