mcoulter's avatar
mcoulter
Follower
Nov 13, 2015
Vlan setup issues
We are trying to setup VLANs on two M5300 stacked switches (many more to add later but starting simple).  By default we have everything on VLAN 1 and all the ports are Untagged.  I'm using VLAN 7 for a test.  I've tried setting up my test port to my desktop to VLAN 7 while all the other ports are set to except all VLANs and I get no traffic.  If I Tag the port for the router on the VLANs, I actually get no traffic on either VLAN.  I'm must be missing something.  If I step back, and simply just work with VLAN1 and I Tag the port for the router, I lose all traffic internal and external.
1 Reply
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello mcoulter,
    Welcome to the community!
    The port where you connect the router (should be VLAN-aware router) should be tagged and the ports where you connect computers (or any VLAN-unaware LAN devices such as pass through switch, printers, etc.) should be untagged. Remember that you also need to change the PVID of the untagged ports, PVID =VLAN ID. Tagged ports' PVID need to to be changed.
ProSupport for Business
