LANshake
Sep 19, 2012Aspirant
VLAN setup on Smart switches
Hardware: one GS716T one FS726TP one unmanaged switch Network devices: PC's , Printers, NAS IP cameras, video server VoIP Polycom phones (upcoming install) PC's and general network device...
kofi
LANshake wrote:
Logical to use GS716T as top level switch in network ?
Yes, considering your list of switches it's the mos powerful.
LANshake wrote:
Start out with three VLANs. [...]
Looking for configuration recommendations.
Smart Switches should also be able to use Auto VOIP VLAN, so yes you can separate that into a extra subnet.
Since the smart switches will (at maximum) support static routing, you'll at some point need separate a "router on a stick" for inter-vlan routing or shared internet access.
3 VLANs make sense if you need to separate the video stuff from the rest of the network.
