AOS-STAHL-IT
Dec 07, 2016Aspirant
VLAN splitted IT and Telephone configuration
Dear Community, I'm currently setting up a configuration and this point the problem is that the telephones do not send their DHCP Request to the Router behind the Switch. I assume this might be a...
- Mar 01, 2017
Just following-up on this. I inquired your concern to a higher tier of NETGEAR Support as well as the options mentioned by your vendor and here is the feedback I got:
Both of the vendor comments are correct, but they are depending on how you use the phones:
Option 1 is only valid if the PC connects into a LAN port on the phone, and the phone connects into the switch, this would be using a Tagged port on the switch. It seems that you will not use this. In this option the PVID is not relevant as PVID is not relevant on a Tagged port.
Option 2 is also possible to work and in this setup, the untagged port must be set with the correct PVID (assuming it is 3).
Going back to your original post, it mentions that ports 37 to 46 are untagged VLAN 3, yet it doesn’t have a PVID of 3, so effectively they are still operating as untagged in VLAN 1.
Kindly set these ports (which contain phone and the router for the voice network) to be Untagged in VLAN, and also set the PVID to 3 and let us know the outcome.
This port 37 on your config, there is no PVID set, so default is 1
interface 0/37
vlan participation auto 1
vlan participation include 3
exit
This is sample port 23 with PVID set to 100 from the lab switch:
interface 0/23
vlan pvid 100
vlan participation include 100
exitRegards,
DaneA
NETGEAR Community Team
DaneA
Dec 12, 2016NETGEAR Employee Retired
Hi AOS-STAHL-IT,
I am glad that the phones are now able to ping the local router. :) The phones are VLAN-aware devices that is why we need to set the ports as tagged ports.
About your other site, you might need to double-check the routing as well as the VLAN tagging.
DaneA
AOS-STAHL-IT
Dec 13, 2016Aspirant
But i dont want the phones the to know in what VLAN they are. as well as the other local Telefon-equipment and the router.
cause of this I might have to do changes on the router and other equipment.
this is not how it was meant to be..
- DaneADec 13, 2016NETGEAR Employee Retired
Hi AOS-STAHL-IT,
As far as I know, it will not work if the ports where the phones are connected are not set as tagged ports. Let me share this article and it might be useful on the changes you will do.Regards,
DaneA
- AOS-STAHL-ITDec 14, 2016Aspirant
hmmm okay, i might have to rethink my setup... I will also have to speak to the ISP of the VPN (MPLS) to adjust the routers so that they are aware and make use of the vlan.
I dont know if I want to use OUI and AutoVoice Vlan or if I want to create a new VLAN for our Telefones. I also did use the one Wire to the Desk concept.
I will have to reconsider this topic and to some testing.
I will come back to this thread within the next weeks (maybe after the holidays) and update my learning for others.
Kind Regards,
Michael
- DaneAJan 09, 2017NETGEAR Employee Retired
