s_triv
Feb 26, 2015Aspirant
Vlan Tagging, Port Trunking Switch along with Unmanaged Switch
Hi Might be a basic question but I am in the process of designing a network which will involve me creating some Vlans and some port trunking. I have netgear GT108 V2 switches which I believe sup...
fordem
Feb 26, 2015Mentor
s_triv wrote:
Now my question is if I connect the vlan tagged ports from the above switches to some netgear unmanaged switch just for the sake of multiplying ports to connect to various PCs, will it even work ?
And will it maintain the vlan and won't go crazy ? :eek:
If the ports are being used to connect PCs, you most likely will want them "untagged", and, yes, you can connect a "non-VLAN-aware" switch to an untagged port on a "VLAN-aware" switch and all the ports will be members of whatever VLAN the port is configured for.
Also connected to this, I will need to share a common printer above separate LANs (on separate vlan). is that even possible ? :o
Yes, this IS possible, however making it happen can be a challenge.
I often question WHY people choose to VLAN their networks - it's often done because of a misguided belief that it enhances security - which it can in a properly designed infrastructure, but in the average SMB environment, it just gets in the way of sharing the resources that are the reason the network exists.
