Fannels
Jun 21, 2018Aspirant
VLAN's not talking to eachother
I have setup vlan 10 and 20 192.168.10.1 and 192.168.20.1 on my routing table,
Port G1 and G2 have both vlans on them but i cannot ping the pc in the vlan 20 range from the vlan 10 port
I...
schumaku
Jun 21, 2018Guru - Experienced User
The PCs involved are making use of the related switch LAN IP for the routing ie. each it's .1 for the default gateway?
Fannels
Yes on the pc i had 192.168.10.99/24 with gateway 192.168.10.1 for VLAN 10
192.168.20.1/24 with GW 192.168.20.1
They still dont want to comunicate
i also followed these steps using routing wizzard and no coms.
https://drive.google.com/file/u/1/d/0B4PuVEYxkQ5oX0w0Yll0U1d2MlE/view?pli=1
