TedW
Aug 07, 2017Aspirant
Voice VLAN trinking M5300 to S3300 with Auto-VoIP
I just finished getting my VLAN trunking and Auto-VoIP working to a new S3300 switch from a trunked port out of my M5300, but I had a quite a time getting it to work. For the longest time, I coul...
- Aug 07, 2017
Hey,
As you know, OUI based Auto-VoIP assigns devices to a VLAN based on the MAC address (in fact based on the OUI, not the entire MAC address).
Protocol based Auto-VoIP assigns devices to a VLAN based on the type of traffic they send. It would probably be something like "If the device is sending traffic to destination port 5060, then assign the device to VLAN x " (5060 is the common VoIP port).
You should not use both these at the same time, which could easily be why your config was not working :)
Cheers
