KelvinFu's avatar
KelvinFu
VoIP Setting in multiple switches scenario
Hi All,
We are currently implementating an IP Phone project which requires me to modify the setting on core switch (M4300 x 2 stacked) and Smart Layer 2 switch (GS752TP), I did have some research on those products individually, but I have no idea on how it can be done on multiple switches environment. I appreicaate if anyone could share your experince on the configuration on core and layer 2 switch or give me a hints? Thank you.
i.e. network topology attached
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi KelvinFu,
    As long as the switches are trunk to each other then you will have no problems on the implementation of your IP phones. Any particular settings that we need to do on the switch in order for us to provide you some instructions?
  • JohnC_V's avatar
    JohnC_V
    KelvinFu,
    I would like to have a follow up on this thread. Please let us know if everything is ok now or you still need further assistance.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
