malamaka
Feb 01, 2019Follower
Want to bond two licensed WiFi links
Hi,
I want to bond two licensed wifi links together where each is now giving 500 mbps, I want a 1 gig link.
What do you recommend using and how?
DaneA
Feb 04, 2019NETGEAR Employee Retired
Hi malamaka,
Welcome to the community! :)
You mentioned "wifi links" - there is no option to bond wifi links. It could be that you are referring to bond ethernet links on managed switches.
I recommend you the M4300 series switches. For more information, kindly access the link below:
Click also on the link below to check other NETGEAR ProSAFE Switches that might fit your network requirements:
DaneA
NETGEAR Community Team
