jibun-no-kage
Feb 03, 2025Follower
WAX220 Power Orange and Blinking Only When Plugged Into MS108EUP?
I have 2 WAX220 access points that seem to be functioning, they show connected clients. However when either of the WAX220 units are plugged into my new MS108EUP (8 port POE switch) the power LED on ...
BrianL
Feb 05, 2025NETGEAR Moderator
Hi jibun-no-kage,
Welcome to the community!
Just to add from what FURRYe38 have suggested, you may want to check the ethernet cable/s you were using and also you can set the POE port settings where the AP is connected to deliver power at 802.3at which the WAX220 would require. If the AP continues to misbehave, kindly share a snapshot of the POE port status of the switch showing the port where the said AP is connected.
Kind regards,
BrianL
