velis
Jun 21, 2016Aspirant
What are commands dealing with PoE on a M4100 type switch
I would like to power-manage devices connected to the switch, e.g. turn them off for the night. I wanted to write a CRON job (I'm assuming the switch in question is running CRON) which would do th...
- Jun 28, 2016
Hi velis,
I have inquired your concern to a higher tier of NETGEAR Support. I'm afraid to inform you that it is not possible to do what you require unfortunately. Via the CLI access, it is only possible to run commands capable of applying/editing changes to the configuration of the switch not any changes to the OS of the switch.
DaneA
NETGEAR Community Team
velis
The manual doesn't help:
I connect via telnet. However, the list of supported commands is practically blank: Ezconfig, enable, help, logout, password, ping, quit, show and telnet.
If I try to enter "poe", I would expect to get a help on using the command. What I get, however, is a syntax error, pointing to the letter "o".
I would appreciate a guide on this.
Edit: OK, I found that I need to enable the appropriate mode before this will be accepted. This means a lot more reading of that manual. I don't see however, how I can progress from this *designed for interactive management* into a script that would do what I want. Obviously this manual is not the way.
