velis's avatar
velis
What are commands dealing with PoE on a M4100 type switch
I would like to power-manage devices connected to the switch, e.g. turn them off for the night. I wanted to write a CRON job (I'm assuming the switch in question is running CRON) which would do th...
  • DaneA's avatar
    DaneA
    Jun 28, 2016
    Hi velis,
    I have inquired your concern to a higher tier of NETGEAR Support.  I'm afraid to inform you that it is not possible to do what you require unfortunately.  Via the CLI access, it is only possible to run commands capable of applying/editing changes to the configuration of the switch not any changes to the OS of the switch.
    DaneA
    NETGEAR Community Team
ProSupport for Business
