alpha754293
Dec 03, 2019Guide
Where can I find more information about LAG options?
Hi there. I'm new here. I have a GSM7248 v2h1 48-port L2 managed gigabit ethernet switch and in regards to link aggregation groups (LAG), in the manual for the 7000-series managed switches, on ...
JohnC_V
Dec 06, 2019NETGEAR Employee Retired
Welcome to our community! :)
We do have a lot of articles for setting up our switches. I have provided some below:
- What are Link Aggregation Groups (LAGs) and how do they work with my managed switch?
- What is SpanningTree Protocol (STP) and how does it work with my managed switch?
- Admin mode is to enable/disable the port.
I hope it helps :)
John
NETGEAR Community Team
- alpha754293Dec 06, 2019Guide
JohnC_V wrote:Welcome to our community! :)
I hope it helps :)
John
Thank you for your reply. That's useful (in explaining or pointing me to look up, on Wikipedia, what STP is and what it does). I'm not sure if it is used by default, (when neither LAGs nor VLANs are present), but I have to start the journey of learning somewhere.
What about link traps? What are they and/or where can I find more information about that?
Is static mode the way to PREVENT dynamic link aggregation (LACP)?
Thank you.
