alpha754293
Dec 03, 2019Guide
Where can I find more information about LAG options?
Hi there. I'm new here. I have a GSM7248 v2h1 48-port L2 managed gigabit ethernet switch and in regards to link aggregation groups (LAG), in the manual for the 7000-series managed switches, on ...
JohnC_V
Dec 06, 2019NETGEAR Employee Retired
STP is preventing loops in your network that results to a broadcast storm. If Link Traps is enabled then a trap will be sent if the LAG link state changes. LAG/LACP will only depend if the device that will be connected either supports LAG/LACP. It is just that LAG is static configuration while LACP is dynamic.
John
NETGEAR Community Team
