milp
Nov 28, 2020Tutor
Which SFP+ 10GB Transceiver do I need to connect to an Aruba switch?
I need to connect a M4300-24X24F over FO to an Aruba 3810M Switch. The distance is about 200m with OM4 50/125 μm. The Aruba guy told me that he is using the following Transceiver: "J9150D Aruba 1...
- Nov 28, 2020
AXM761 should be right - LC Lucent Connector (all SFP/SFP+ have it), short range (SR), MMF multi-mode [50/125µm OM3 or OM4 so called laser optimized] fiber. What's not explicitly listed on both models is the 850 nm laser wavelength, de-facto standard on multimode fiber.
For a direct connection, you need a dual/duplex multimode fiber with at least OM3, or OM4 (both typically aqua) quality with dual LC connectors on bot ends (typically grey). OM1/OM2 62.5/125µm [typically orange] isn't sufficient - it won't make the distance required because of the 62.5µm core does not fit the Laser sender/receiver.
schumaku
Nov 28, 2020Guru - Experienced User
milp
Nov 28, 2020Tutor
Thanks a lot for the clarification, schumaku
Connection is
AXM761 --> orange patch cable (2m) --> PP --> OM4 (ca. 200m I think) --> PP --> orange patch cable (2m) --> J9150D Aruba Transceiver
So I guess we are all good.
Many thanks.
Daniel
- schumakuNov 28, 2020Guru - Experienced User
Orange coloured patch cable stinks - can be anything from the FDDI to OM1 or OM2, wrong core diameter - check the printing on it. Patch cables must be OM3 or OM4.
