Ycommeyoyo
Sep 03, 2020Aspirant
Transceiver compatibility
Hello,
Is the Netgear 10GBASE-SR AXM761 SFP+ Transceiver compatible with the M4300-24x24F switch ? It should be but I only see in the product overview that fits into SFP+ interfaces of M5300, M7100 and M7300 and select Smart and Plus Switches.
Thank you in advance
Thanks!
The M4300 Series switch product datasheet is your friend - p.23
- YcommeyoyoAspirant
Thanks!
