ProjectEdu
Feb 15, 2022Aspirant
Whitelist MAC-Addresses on GS724T
Hello, how should I configure the GS724Tv4 Switch, to just allow certain devices the communication? I need this for a school project, my idea was to just allow certain Mac-Addresses, so devices ...
- Feb 17, 2022
Hi ProjectEdu,
Yes, you're right. You could whitelist certain MAC addresses on a particular port and limit it to a certain number depending on your preference but it'll take a while to configure it.
An easier way is to use MAC ACL (not sure if you tried this as well) which is used to permit or deny access to the network, please check this guide on how to configure it.
As for the devices that should not communicate with each other even though they're connected to the same switch, you'll need to configure a VLAN (you may refer here in this KB article).
JeraldM
NETGEAR Community Team
JeraldM
Feb 15, 2022NETGEAR Employee Retired
Welcome to the community!
You could use Port Security in this case. Please refer to page 203 of the user manual here for more information.
JeraldM
- ProjectEduFeb 16, 2022Aspirant
Hi, thank for the response!
But how should I configure that, as far as I understood Port Security is for limiting MACs learned by the Ports.
- JeraldMFeb 17, 2022NETGEAR Employee Retired
Hi ProjectEdu,
JeraldM
- ProjectEduFeb 21, 2022Aspirant
Hello, JeraldM
ACL Filter worked, just had to put in the MAC Mask as well as the MAC-Addressa and then it worked perfectly fine. Thank you :)
