enkrypt3d's avatar
Jun 07, 2017
XS708E Slow Throughput?
Hi I have my windows PC connected using the X540-T2 NIC with a cat 6A cable and only getting about 400MB/s to my Netgear 524X... Not sure if I should be getting more? Other NAS's should be able to push further right?
my PC specs:
Xeon e5-2699 v4
Asus x99-E WS motherboard
64 GB DDR4 RAM
  • XavierLL's avatar
    XavierLL
    NETGEAR Employee Retired
    HI enkrypt3d,
    Thanks for sharing your configuration, have you done the tests with a PC directly connected to the NAS or through the switch?  have you notice any performance degradation when  you use the switch ?
    Looking at the current set up one of the bottlenecks that could limit to 500MB/s it's the current drive performance, If you are using SATA 500MB/s looks a really good benchmark .  Moreover the type of RAID will also impact on the performance, in this case you should use RAID 0,1 or a combination like RAID10 to get the best performance .
    Hope it helps!
    Xavier Lleixa
    NETGEAR CBU PLM
    • enkrypt3d's avatar
      enkrypt3d
      Tutor
      I'm using the default XRAID2 setup (RAID5) and there are 4 x 4TB drives SATA 6Gbps... One drive can do roughly 300MB/s so I should be able to see more than 400MB/s...... I have not yet tried connecting directly to the PC though. Doing a sync right now with another NAS that is running - this has not impacted performance at all. Also resync is running. Once these jobs are done I'll retest.
      • XavierLL's avatar
        XavierLL
        Thanks enkryptd3,
        The 300MB/s it's really in an ideal situation but really difficult to replicate in a real environment, normally we get arround 100MB/s on a really good environment (see below a performance test):
        With  RAID 5 and 4 drives you can expect to boost the 100MB/s to arround 200-300MB/s consistent throughput.
        But please let us know what are your results with your latest tests.
        Xavier Lleixa
        NETGEAR CBU PLM
ProSupport for Business
