snik1
Sep 06, 2018Initiate
XS712 not responding - need to contact support for RMA
Hello,
So my XS712T switch decided to go belly up. Have tried factory resets etc. but it's not discovered anymore (not even on default ip). It seems to boot fine, green light comes on etc. All port...
- Sep 06, 2018
Hi Sam,
Start about here - it must be a well-kept secret ....:
myNetgear -> My Support -> [Contact Support] -> Replace my defective product -> select the switch from the product list -> you will get a contact information -> provide some descriptive text ...
schumaku
Sep 06, 2018Guru - Experienced User
Hi Sam,
snik1
Thank you very much. Got a phonenumber to call at the end.
