BobZelin
Feb 15, 2020Star
XS728T / XS748T ports fail - numerous installations
Hi -
this might be my first post here, but I am a long time Netgear 10G switch user - from the original XS712T.
I have seen this problem over and over again, and I am very familiar with the entire 10G XS series of Netgear switches
from the XS708T, XS712T, XS716T, XS728T and XS748T - including all the v2 and E models as well.
I only see this on the XS728T, and XS748T. For no apparant reason, ports will occationally stop working on the switch.
The GUI shows no link, and there are no lights on the ports. Switch to another port - no problems. What I used to do is
do a factory default on the switch, and the ports would come back to life. I searched this forum about a year ago, and I saw
someone's suggestion that you switch the "dead port" speed from Auto to 1G Ethernet, click Apply, and then switch back to Auto, and click apply again, and the port comes back to life. That occationally works.
I just received a call from a client that has a 6 month old XS748T, latest firmware 6.5.1.42, and this happened again - several ports have "died". I logged into their system, and tried my "trick" of switching the dead ports (using a working port) to 1G Ethernet, and then back to Auto, but this time, it did not work. So I am going in there on Monday to do a Factory Default - I assume that everything will start working again, and all ports will come back to life.
WHY DOES THIS HAPPEN? This NEVER happens on an XS708T, XS712T or XS716T !
I would appreciate any advice.
Thanks -
Bob Zelin
- DaneANETGEAR Employee Retired
Is the XS748T connected to another switch? Kindly check the physical connections. There might be a loop causing it. Be sure that STP is enabled on the switches and the STP Operation Mode are the same on all switches.
If ever you already did a factory reset and the same problem occurs, kindly download the Tech Support file (read instructions on page 358 of the XS748T user manual here). Then, open a support ticket with NETGEAR Support here and state your concern as well as attach the Tech Support file for further investigation.
DaneA
NETGEAR Community Team
Hello DaneA -
thank you very much for your prompt reply.
There is no other switch connected to the XS748T. There is no loop.
I hope that I do not sound rude in my reply here - I know that I often do. I have installed possibly 1000 Netgear XS series 10G
switches. As I stated in my original post, I only see "dead ports" (which are not really dead) on the XS728T and XS748T.
I see this problem occur in almost every installation. Eventually, people will call me and say "we can't connect to the server" - and
I right away go to the Netgear XS series switch GUI, and can see "no link" on that port (or several ports) - while the other ports
remain operational. The connection to the Netgear switches vary from Apple iMac Pro 10G ports (Aquantia 10G chips), to
various thunderbolt to 10G adapters from Sonnet (Solo 10G, Twin 10G), Promise (SanLink2, SanLink3) and QNAP (QNAP-T310G1T).
This issue has been going on for years, in hundreds of installations, thru various firmware updates. My current issue, which I will resolve on Monday with this clients XS748T will be to simply do a factory default, and I am sure that all the "dead ports" will start working again. I find it hard to believe that this is not a common issue reported to Netgear on these models.
You will see in this Netgear thread, that this is where I learned the trick of switching between Auto and 1G and back to Auto to
sometimes get the dead port to work again -
I would like to know why the ports stop working, but then can be reactived by either this trick, or factory default.
Thank you for looking into this -
Below I will show some of the text of this link -
Bob Zelin
"We had our XS728T replaced after several of the ports would no longer negotiate a connection over CAT-6 and CAT-6a cables longer than a few meters. Firmware updates, factory reset e.t.c. did not help. After contacting support a replacement was issued. The replacement worked fine for a few days, then ports that were working fine all of a sudden stopped working, and would no longer negotiate a connection (like the last switch). A week later another port dropped off. NETGEAR Support instructed a factory reset. We did so, but this did not help.
What did help, at the suggestion of NETGEAR Support, was to go to Switching > Ports > Port Configuration, then change the Admin mode of the problematic ports from Enable to Disable, then back to Enable. After that 3 of the 4 problematic ports started working correctly and would negotiate at the full 10G. 1 port would now negotiate a connection, but only at 1G instead of 10G. I then changed the Port Speed to 1G Full Duplex and back to Auto. After this the port negotiated properly at 10G (the device must be connected when you do this otherwise it won't work)."
- PhillipCPAspirant
Are you utilizing any 10GB rack mounted or inline surge protectors? Did you ever find a solution for the ports randomly turning off on the XS748t?
Thanks!
