PC53's avatar
PC53
Follower
May 21, 2019
XSM4316S setup
The setup guide video at: https://youtu.be/A9aaG4ic5GU is great but...
At 1:45 into the video, the presenter says something I can't make out about 'connecting the zeebee (or something that sounds like zeebee) management platform'   -  What is that???
Thanks, PC
  • Hi PC53,
    Welcome to the community! :)
    The presenter mentioned ZeeVee.  According to Google, ZeeVee is a developer of digital technology and products for distributing audio-video content from any source or multiple sources to any number of displays.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi PC53,
    DaneA
ProSupport for Business
