Nusratly
Jun 07, 2025Aspirant
2 LANS on one switch?
I have a new GS728TPPV3. My question is can I dedicate some ports to 10.0.x.x and some to 192.168.x.x on the same switch?
schumaku
Jun 08, 2025Guru - Experienced User
Yes, of course you can configure multiple VLANs, on any Easy Smart, Plus, and Smart Switches (of course Fully Managed Switches, too.
Please tell us a little bit more about the two network,nthe topology, the number of devices to be xp texted to each of the two networks - and last but not least on the router or routers you intend to operate these two networks on. The switch does not care much about the two IP subnets, as long as you don't expect the switch doing short cut IPv4 routing between these.
-Kurt.
