Nusratly
Jun 07, 2025Aspirant
2 LANS on one switch?
I have a new GS728TPPV3. My question is can I dedicate some ports to 10.0.x.x and some to 192.168.x.x on the same switch?
Nusratly
Jun 09, 2025Aspirant
These are generic ONVIF security cameras labeled as "GW" brand. Model # GW4571MIP. I bought them in about 2016. The things you are saying to me are way above my expertise.
Jun 10, 2025Guru - Experienced User
Nusratly wrote:These are generic ONVIF security cameras labeled as "GW" brand. Model # GW4571MIP. I bought them in about 2016. The things you are saying to me are way above my expertise.
I think you should contact GW Security and see if they can help you track down the software tools you need (and definitively identify your old camera model).
I took a quick look at one of their manuals, and they use a software tool that can find the camera and then change the IP address from there. There might be a way to do this from your browser, but that would also require you to know the default password for the camera (not just how to set up your network to the right subnet).
Did you also get their NVR? Or just the cameras?
