Nusratly
Jun 07, 2025Aspirant
2 LANS on one switch?
I have a new GS728TPPV3. My question is can I dedicate some ports to 10.0.x.x and some to 192.168.x.x on the same switch?
Nusratly
Jun 16, 2025Aspirant
I set up this network in about 2015 from scratch on the 10.x network. You are correct it would be a pain in the neck to rebuild dozens of devices to the 192.x. So, It seems to me that the easiest and best way to do this is reconfigure half the ports to 192.x leaving the other half on the 10.x network. Can you show me a document in the simplest way to do this?
