pbuckner
Dec 18, 2020Aspirant
308t switch crashes daily, after 35 minutes when attached to Orbi Satellite
Looking to attach NAS near a PC which will be using a majority of the storage. I use 308T because I can link aggregate. (308E does not). Problem: 308T crashes (loses all connectivity) after about...
- Dec 19, 2020
Does not look good - I would suggest to look into getting a warranty replacement, depending on the market from your retailer or via Netgear https.//my.netgear.com/
schumaku
Dec 19, 2020Guru - Experienced User
Don't panic about the in-line images - these are under mandatory moderation. Better approach than reposting would be adding a copy an additional attachment.
Is the switch management IP no longer pingable over the Orbi WiFi and mesh, and no longer pingable from the direct connected NAS, and no longer pingable from a computer connected to the switch?
pbuckner
Dec 19, 2020Aspirant
Correct, switch is no longer pingable from anywhere.
Ran another test overnight, with 308T directly connected to main Orbi RBR: Nothing else connected to the switch. It was pingable for 11 hours then "Unreachable". (I use basic 1sec ping)
I suspect the 308T is bad?
