pbuckner
Dec 18, 2020Aspirant
308t switch crashes daily, after 35 minutes when attached to Orbi Satellite
Looking to attach NAS near a PC which will be using a majority of the storage. I use 308T because I can link aggregate. (308E does not). Problem: 308T crashes (loses all connectivity) after about...
- Dec 19, 2020
Does not look good - I would suggest to look into getting a warranty replacement, depending on the market from your retailer or via Netgear https.//my.netgear.com/
pbuckner
Dec 19, 2020Aspirant
Correct, switch is no longer pingable from anywhere.
Ran another test overnight, with 308T directly connected to main Orbi RBR: Nothing else connected to the switch. It was pingable for 11 hours then "Unreachable". (I use basic 1sec ping)
I suspect the 308T is bad?
schumaku
Dec 19, 2020Guru - Experienced User
