tahiti25
Nov 03, 2017Aspirant
Accidentally disabled admin on all ports GS110tp
I am new to this forum so please be patient. I had to disable all ports which were connected to wireless radios for a 3rd party firm to access and service there equipment neighbouring ours, however I inadvertently selected all ports to be disabled including the fibre port which I was actually connected over. The switch I located in a plant area where I do not have easy access just checking if there is anything I can do or is it going to be a factory reset? A schoolboy/girl error.
Thanks for the update. I'm glad that it worked after doing a factory reset. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Welcome to the community! :)
I'm afraid that we need to perform a factory reset on the GS110TP switch then reconfigure the settings from scratch since there is no way to manage the GS110TP switch anymore because all ports were disabled accidentally.
DaneA
NETGEAR Community Team- DaneANETGEAR Employee Retired
I just want to follow-up on this. We’d greatly appreciate your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance.
If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
- tahiti25AspirantYes thanks, factory reset worked.
