guild
Dec 23, 2018Aspirant
adding JGS524Ev2 SmartPlus to JGS524Ev2 SmartPro
i have a JGS524Ev2 SmartPro and want to get another. Netgear had a link to Amazon showing the JGS524E-200NAS, as either {Layer 2 SmartPro} and {Layer2+ SmartPlus}. about a $40 difference for SmartPlu...
- Dec 23, 2018
guild wrote:
i have a JGS524Ev2 SmartPro and want to get another. Netgear had a link to Amazon showing the JGS524E-200NAS, as either {Layer 2 SmartPro} and {Layer2+ SmartPlus}. about a $40 difference for SmartPlus.
The XXXnnnE are all Smart Managed Plus switches on new marketing terms, not Pro. If you check the JGS524Ev2 label, most likley it says JGS524E-200[xxx], too. So all the same switches. Poor seller marketing, wrong, and misleading information claiming Pro.
guild wrote:
q1). what is the 200NAS label?
200 is the hardware version 2, NAS is the packaging (power supply/power cable/documentation language). So this is (again) a JGS524Ev2.
guild wrote:
q2) would daisy chaining the SmartPlus with my current SmartPro be an issue or better to stick with the SmartPro?
No problem to daisy chain two switches. If you require more bandwidth, consider to configure a trunk. As mentioned above, these are Smart Manged Plus class devices.
schumaku
Dec 23, 2018Guru - Experienced User
guild
i see, i'll stick with the SmartPlus then, save a few bucks. does basically what my home requriements are.
thanks for the explanations and help!!
