MLVoDaVi's avatar
MLVoDaVi
Follower
Jul 24, 2023
Adding VLAN
Good morning,
I am having issues setting up a VoIP VLAN. I have the VLAN Tagged on the interface connecting to the firewall. I have the VLAN Tagged for all uplinks to other switches that will be holding that VLAN. From both of the switches I can PING the VLAN 200 interface. 172.16.200.1 that exist on the firewall. The phones are not registering. When a phone is placed on the user VLAN it will register and work no problem. So there is missing piece in the configuration.
I am working via Insight remotley and am avaible all day to work on this.
Thank you.
  • schumaku's avatar
    schumaku
    A little bit vague of what you like to achieve with the VoIP VLAN in general, and what exactly you expect for the switch ports for IP-phones and/or for generic data devices.
    Start about here: How do I set up a VOIP VLAN in Insight?
    • a01's avatar
      a01
      Guide
      Are the ports connecting to the phones untagged and the same VID is set as the PVID?
ProSupport for Business
