monnier's avatar
monnier
Administration POE
Hello,
When I want to configure the POE, I have a message loading page and that's it. the display is not done.
So I can't configure the POE
Best regards
  • plemans's avatar
    Have you tried different web browsers or pc's?
    • monnier's avatar
      monnier
      I tested with GOOGLE CHROME, EDGE, INTERNET EXPLORER.
      2 different PC
      I have other netgear switchs:
      GS510TPP x 2
      GS716TPP x 2
      GS728TXP x 2
      I do not have this problem
  • schumaku's avatar
    schumaku
    monnier Does the switch power a 802.11afv or a .11at PD?
    Remeber havibg seen sich an issue on a PoE dwotch with a defective PoE unit.
    • monnier's avatar
      monnier
      Hello,
      I don't know,
      where can I find this information
      I have a NETGEAR 48-Port Gigabit PoE+ Smart Managed Pro Switch with 4 SFP Ports (GS752TPv2)
      • schumaku's avatar
        schumaku
        monnier wrote:
        I don't know, where can I find this information
        Aehm, this information would come from the PD (PoE client) devices specifications - as we can't check the PoE status et all.
        Does the switch power your connected PoE or PoE+ devices at all?
ProSupport for Business
