patreeek
Feb 03, 2026Tutor
Advanced 802.1Q VLAN Doesn't Block Untagged Traffic?
I think the answer might be obvious. Lower-end Netgear switches are not managed using VLAN traffic, so they allow all untagged traffic to pass through. Is this correct?
For example, a port is c...
schumaku
Feb 03, 2026Guru - Experienced User
patreeek wrote:Lower-end Netgear switches are not managed using VLAN traffic
Most Easy Smart Plus are indeed not built around a managed switch core. The management Web UI (or for the sake the legacy [known vulnerable] Netgear Switch Discovery protocol that can be enabled for discovery -and- for the administration does only accept untagged traffic. Said this: Any untagged frames coming to the switch on an untagged network can be "abused" to discover and access the admin - select NTGR Plus Switches (newly nicknamed NTGR Easy Smart Managed Essentials Switch) might have a simple IP based filter to "protect" the simple controls.
patreeek wrote:they allow all untagged traffic to pass through. Is this correct?
Yes, you can configure multiple logically isolated VLANs. The traffic on the port(s) can be both [U]ntagged (with the PVID set accordingly) and [T]agged. Yes, all these frames can pass the switch.
patreeek wrote:For example, a port is configured with VLAN ID 10 for untagged traffic and its PVID is 10. It will tag the traffic correctly and all the traffic will go to the correct subnet
To the appropriate VLAN, yes. The switch does not care about the IP subnets.
patreeek wrote:if I manually configure my IP, I can access any other device on the link that is not VLAN aware.
From a device connected to an [U]ntagged port on the switch, to another device on an [U]ntagged port. Correct.
patreeek wrote:This could be another Netgear switch
Any switch.
patreeek wrote:or a MoCA device
As loig as these frames are [U]ntagged, yes.
Double and triple check the MoCA devices (or any other Ethernet bridge devices, like WiFi bridges, ...) you have in mind for passing [T]agged traffic. Not all will pass 802.1q tagged frames.
Confusion complete?
-Kurt.
