hohojojo
Jan 03, 2018Aspirant
advise for buying switches and creation SFP trunk
Dear community, As I am new to managed Switches I would like to have some advise before buying 2 switches. I need to connect 2 switches, one in a small office and one in home, approx. 50 meters ...
- Jan 09, 2018
Yes, you may use the S3300-28X (GS728TX) for trunking and LACP. It is also possible to create LAG between two switches as long as the switches that you are going to use supports LAG. If you wanted a device that supports stacking feature then the GS728TXS will do.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnC_V
Jan 05, 2018NETGEAR Employee Retired
Hi hohojojo,
Welcome to our community!
Unfortunately, GS724T does not support stacking features. It will be possible if you may check this stackable switches that we have.
