lee_zhou_cn
Dec 26, 2020Aspirant
After GS116eV2 update firmware to 2.6.0.48, I lost my web admin service.
After I update the firmware to 2.6.0.48, there has no Web Admin Service anymore. I had run PortScan for the switch, only found 4 active port, those are : Port Scanning host: 192.168.x.x ...
schumaku
Dec 29, 2020Guru - Experienced User
lee_zhou_cn wrote:I had run PortScan for the switch, only found 4 active port, those are :
Open TCP Port: 110 pop3
Open TCP Port: 143 imap
Open TCP Port: 993 imaps
Open TCP Port: 995 pop3s
This looks much more like a mail server than a switch. Try the NSDT to discover the switch IP on the LAN.
- lee_zhou_cnDec 29, 2020Aspirant
The NTSP discover same switch which has Mail server ports : -<
I had run telnet with port 80/443 for the switch :
Trying 192.168.xxx.xx...
telnet: connect to address 192.168.xxx.xx: Connection refused
telnet: Unable to connect to remote host
And run telnet with 110/143/993/995 is :
Connected to 192.168.xxx.xx.
Escape character is '^]'.
Connection closed by foreign host.
- schumakuDec 29, 2020Guru - Experienced User
Factory reset ... and power it off (duplicate address on the network?)
Whie talking, you don't have to mask the RFC1918 addresses - we're all using the same.
Try the default config, with a direct connection to the 192.168.0.239/24 address with a direct connection from a computer interface on that same subnet.
