Chipperchoi
May 03, 2021Aspirant
Amnesia:33 vulnerabilities for JGS516PE
Hello all,
I am not having much luck in finding any information regarding the Amnesia:33 vulnerabilities showing up on our Qualys scan for the JGS516PE switch.
I understand that the switch is EOL and no longer supported but is there any information about the latest patch from them addresses the vulnerability mentioned?
- ChipperchoiAspirant
That link doesn't address my question.
If I were to report this, which is an old CVE by the way, will there be fixes for it if the product is EOL?
It is a well known issue with opensource TCP/IP stack.- schumakuGuru - Experienced User
Chipperchoi wrote:It is a well known issue with opensource TCP/IP stack.
Not sure there are similar alternate robust and light TCP stacks available to replace these embedded microcontrollers TCP stacks not vulnerable to the Amnesia:33 set.
Even if available, unclear if the industry will update these tiny devices ever.
YeZ please.
