algutier
Oct 28, 2024Follower
backup GS110TPv3
II’d like to know if it’s possible to set up an automatic daily backup for my Netgear GS110TPv3 switch. I know how to manually save the configuration file, but I’d like to automate the process so tha...
schumaku
Nov 03, 2024Guru - Experienced User
Consult to fine manual -> 8-Port Gigabit (PoE+) Ethernet Smart Managed Pro Switch with (2 SFP Ports and) Cloud Management Models GS108Tv3, GS110TPv3, and GS110TPP User Manual
Export a file from the switch
You can export configuration (ASCII) or log (ASCII log) files from the switch to a file server by using TFTP or to a computer by using HTTP.
The following sections describe how you can export a file from the switch:
- Use TFTP to export a file from the switch to a TFTP server on page 436
- Use HTTP to export a file from the switch to a computer on page 438
