Szymon-ek
Jun 06, 2021Aspirant
brick JGS524PE
Hello ! I have JGS524PE unit all led abmber, not work, and keep in loop like that haw to swith to image A ? all commands: boot:boot elite command dump_ctrl:dump ctrl info help:help command res...
Szymon-ek
Jun 07, 2021Aspirant
Hello!
Why Do You think it need to be replaced? Are You Expect Any HARDWARE Problem????
1- if yes then I can replace broken chip - main uC or another ?
2- if not - is firmware problem i can blow new one
The program is in MX25L3206E-12G, and this is 32mbit flash memory. If this content is broken, then I can reflash it using any external flash programmer form provided HEX file
also board include Nuvoton M058SLAN 32bit arm micro controller, if this is problem then also I can re-flash if needed, but it looks like this is more for LED control and FAN
3- if this forum does not have enough qualified person to understand problem on electronic level, then I will need link to correct support team to get guide on next level
4- If 1 -3 not applicable - then I need to transplant flash content from another working unit and share solution with others user on the forum, because problem is common and frequent, but I can’t find any solution other than - if is broken buy new one, or replace on warranty by NETGAR - similar and booth are NOT ENVAIOMATNATL FRENDLY, we produce more electronic rubbish instead fixing them and using again
Regards
Old fashion engineer ;-)
DaneA
Jun 08, 2021NETGEAR Employee Retired
Yes, the hardware is faulty that is why it needs to be replaced. Be informed that the warranty will be voided once you have opened the enclosure of the switch.
DaneA
NETGEAR Community Team
