dean_s's avatar
dean_s
Buffer sizes on XS708E
I'm trying to find the cause of some lost datagrams on my network.  Linux has a socket buffer setting that can cause lost datagrams if it is not large enough.  Does the XS708E have a buffer that coul...
  • Retired_Member's avatar
    Retired_Member
    Oct 26, 2016
    Hi dean_s
    Thanks to provide the feedback.
    You can refer UM (Page 36, manage flow control) to get know how to enable it. To measure the packet drop, suggest to use equipment IXIA, spirent or SMARTBITS.
ProSupport for Business
