Switch5439
Jan 10, 2017Aspirant
R7000 buffering
Trying to get router to work with IPTV, I use an Android device with the Kodi platform with the Lollipop software on 2 boxes and the Krypton on a third. My problem is I keep getting buffering on IPTV as well as on streaming movies over the Kodi boxes. The Netflix account I have added to those devices seems to work fine since I turned on QoS on the router, I have tried disabling IGMP proxing in WAN but it does not seem to help, my internet speed averages 100 to 125 MBS and I am streaming on 5G, my firmware version is V1.0.7.6_1.1.99 . I am running windows 7 professional 64 bit, really like the IPTV but just hate the buffering, does anyone have any ideas???
- OP, try rolling back to the previous 1.0.7.2 drivers to see if that fixes your problem. I had so many issues with 1.0.7.6 in regards to WIFI performance that I had to find out via roll back. Sure enough, buffering and disconnect issues went away.
- OmarDeenAspirantConnect using a Ethernet cable should solve your problem - Switch5439AspirantThanks but that kinda defeats the purpose of having a wifi router when I could have just bought a switch
- xealoAspirantOP, try rolling back to the previous 1.0.7.2 drivers to see if that fixes your problem. I had so many issues with 1.0.7.6 in regards to WIFI performance that I had to find out via roll back. Sure enough, buffering and disconnect issues went away. - Switch5439AspirantThanks I will try that, tried turning off WMM on both 2.4 and 5 G and that seems to help some but I will try the firmware roll back you suggested. Once I download that new firmware do I need to turn on QoS like I have on this version and disable WMM on both 2.4 and 5 G ?
- Switch5439AspirantRolled back the firmware version and also turned off the smart connect feature and that seemed to solve the problem on most channels, there are like 520 to try, but I am really satisfied with the result so far. Thanks so much for the help - OmarDeenAspirantHow are you getting so many channels most Simple Client pvr link I use never connects or is very unreliable. Perhaps I am doing something different in KODI. Would like to know your set up. I can then test my WIFI
- OmarDeenAspirantThanks Todd ! I will check it out
 Omar
