dean_s
Oct 25, 2016Aspirant
Buffer sizes on XS708E
I'm trying to find the cause of some lost datagrams on my network. Linux has a socket buffer setting that can cause lost datagrams if it is not large enough. Does the XS708E have a buffer that coul...
- Retired_MemberOct 26, 2016
Hi dean_s
Thanks to provide the feedback.
You can refer UM (Page 36, manage flow control) to get know how to enable it. To measure the packet drop, suggest to use equipment IXIA, spirent or SMARTBITS.
Retired_Member
Oct 26, 2016Hi dean_s
