Ardje
May 28, 2020Guide
[BUG] GS108tv3 blocks udp broadcasts to port 123
Hi Guys, I was evaluating the GS108Tv3 for table/POS access switch usage. I discovered that third party hardware suddenly was not able to communicatie with eachother anymore, so I investigated it...
- Sep 11, 2020
Update:
We got a beta release 7.0.4.7beta that fixed the issue.
Currently the switch has been running production for 2 months I think, and not a problem that's related to that switch.
Of course I've seen weird things going on in the switch (upnp, weird configuration daemons and such), but it doesn't stop it from working. So that beta seems good.
Changing the management vlan will be my next achievement, I fear I have to do that with scripted tftp download, sed, tftp upload, reboot. As the web doesn't allow it, and the command line doesn't allow it. Maybe if we use the serial console, but we do not intend to solder one on every switch ;-).Anyway, past the initial problems of getting a support ticket opened (the "owner" is a different person than the tech support here), the support crew was helpful in getting it resolved.
Ard van Breemen
schumaku
Jun 05, 2020Guru - Experienced User
YeZ is with Netgear and can talk to the product management internally. I didn't had a chance to chat with him for about two days why ever.
schumaku
You can fetch the running config from the switch by Maintenance - Upload - Text Config to see if there is really such a config in place intentionally.
