Hephaestus1
Jul 22, 2017Aspirant
Can GS108PE provide power only (no data) to GS105PE?
See the picture below. Can it work like that? It apears to me that the answer is: yes, it can. Am I right? Thanks!
- Jul 24, 2017
Hi Hephaestus1,
Welcome to NETGEAR community!:smileyhappy:
I just confirmed that GS108PEv3 could work correctly with your topology.
Let me introduce the step to confirmation your request.
1. Connect AC/DC power to GS108PEv3.
2. Connect PSE port (1~4) to GS105PE PD port(5).
3. Login GS108PEv3 and set Speed to Disable on the port which deliver power to GS105PE.
4. GS105PE work fine and no Ethernet link between GS108PEv3.
You can also check following screenshot for more details.
1. Set Disable on PSE port which deliver power to GS105PE.
May my solution help you:smileyhappy:
You can buy GS108PEv3 and enjoy it
Hephaestus1
Thank you for your response! Yes, I am aware of the power restrictions. My original question could be formulated: is disabling the port in GS108PE going to also disable power delivery through the port? This is what I am uncertain, docs do not help, Internet search also did't bring any joy. There are good reasons why I would prefer not to use VLANs, unless I am forced to. Unfortunatelly this is a pre-sale inquiry and I do not have the switches to try it.
DanielZhang
Jul 24, 2017NETGEAR Expert
Hi Hephaestus1,
- May 25, 2022Retired_Member
