axt
Dec 22, 2015Aspirant
Can I connect 802.3AF devices to my GS510TP
HI,
I have Access Ponits that support the 802.3af standard and am not sure if I bought a GS510TP that I can safely connect thses AP's to the POE+ ports. In the past I have connected these AP's to a POE+ switch but want a smart switch to see what's really happening with the power.
Any help would be apprciated,
Thanks
Steve - AXT
Hello axt - Steve,
The GS510TP does support devices using 802.3af (DTE Power via DMI). You can adjust and configure each port on how you want the PoE to play out. See screenshot below:
I hope this helps, let us know if you have more questions.
Thanks,
1 Reply
- JohnRoNETGEAR Employee Retired
Hello axt - Steve,
Thanks,
