axt's avatar
axt
Can I connect 802.3AF devices to my GS510TP
HI,
I have Access Ponits that support the 802.3af standard and am not sure if I bought a GS510TP that I can safely connect thses AP's to the POE+ ports. In the past I have connected these AP's to a POE+ switch but want a smart switch to see what's really happening with the power.
Any help would be apprciated,
Thanks
Steve - AXT
  • Hello axt - Steve,
    The GS510TP does support devices using 802.3af (DTE Power via DMI). You can adjust and configure each port on how you want the PoE to play out. See screenshot below:
    I hope this helps, let us know if you have more questions.
    Thanks,
1 Reply
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hello axt - Steve,
    Thanks,
ProSupport for Business
