davmerc1
Mar 03, 2022Aspirant
Can ping everything on the internet but cannot access any webpage. Timing out
Hi. I`m new to Netgear switches. Got a bunch of ProSafe GS728TPv2 that I have configured to be like this. User PC (VLAN 10)-- VoIP Phone(VLAN20)--Firewall--Internet. The Users which is in VLAN...
JeraldM
Mar 03, 2022NETGEAR Employee Retired
Welcome to the community!
Try enabling domain lookup by typing "ip domain-lookup" on the CLI.
For further assistance, you can open a support case here.
JeraldM
NETGEAR Community Team
davmerc1
Hi JeraldM
Thanks for the reply.
Apologies the model is GS728TPP. I believe there is no CLI on that model?
- schumakuMar 04, 2022Guru - Experienced User
According to the config posted it's a v2
SYSTEM CONFIG FILE ::= BEGIN ! Model: GS728TPPv2 ...
Since a recent firmware update, the Light CLI was added - consult the https://www.netgear.com/support/product/GS728TPPv2 FMI.
However, the command JeraldM proposed (available typically on managed switches only) is to enable the DNS resolver on the switch management, allowing to use FQDNs e.g. for NTP servers, SNMP trap receivers, ... and has absolute no impact on the switch data traffic. On your current startup FWIW it's disabled by the "no ip domain lookup" - the control is on the DNS Configuration -> DNS Status [x] Disable Enable.
From wally brain, there is no such control on the Light CLI.
Connecting the PC direct to port 1..21, does it allow the Internet access as expected?
Suspect there is some VLAN config inconsistency on your devices and network.
