tonynsx
Jan 12, 2023Luminary
Cannot access web ui, GS308EPP
I have 3 new Netgear GS308EPP. I can ping all 3. But, I can only access the web ui on 2 of the switches. This is what I get, and I tried different browsers also. This page isn’t working 10.0....
tonynsx
Also, is it possible to SSH or telnet into a Netgear managed switch? I use Aruba sometimes, and I can use the web ui and SSH.
How do I do that with Netgear switch?
- tonynsxJan 12, 2023Luminary
I was able to login to the web ui when I configured the switch, that's how I assigned it a static IP. But now I cant access web ui even if I can ping it, and I'm on the same subnet.
- schumakuJan 13, 2023Guru - Experienced User
The smarter way than assign static IPs would be to let the DHCP server assign fixed (reserved) IP addresses to each switch MAC address - much less risk involved having multiple devices on the same LAN with the same IP. Keep in mind this requires a reliable network link at startup, a reliable connection and a cold restart. Yes, hit me these days finding a device Web UI unreachable - looking twice proofed I had the same IP assigned on the subnet twice.
Also keep in mind these switches don't have fixed management VLANs so DHCP can be a hit and miss and any DHCP on the same broadcast domain can succeed.
Last, these are basic switches with Web config options, by far not fully fledged managed switches.
- tonynsxJan 13, 2023Luminary
I'm able to access the web ui from another computer, but not from mine, so I guess its local to my computer.
Is there a way to ssh into Netgear switches?
