AntC's avatar
AntC
Cannot Download Config for GS728TP
Hello, I'm trying to download the configuration of my Netgear GS728TP, but every time I try, I get "Failed - Network error"  message.
Searching the web, I find a lot of people have had this issue but were unable to resolve it, I wonder if there's anything else I could try? I've tired incognito browser, different browsers, connecting alone off the main network, nothing works.
Thanks.
  • I guess when I said " I find a lot of people have had this issue but were unable to resolve it" - that's still the case! Frustrating as there's no way to save any config.
  • FURRYe38's avatar
    Are you using a browser to access the switches WEB page?
    How are you attempting to download the config file?
    Something to contact NG support about...
    BrianL LaurentMa
  • I had the same issue, always got a “Failed - Network Error” no matter what browser or setup I used.
    What finally worked was using Microsoft Edge with Internet Explorer mode enabled. I added the switch's IP under the IE mode settings, and then the config download worked perfectly through the web interface.
    Hope this helps.
ProSupport for Business
