jdmarlow
Jan 05, 2022Guide
Cannot get LAG working on XS708T
I am trying to set up my XS708T with Link Aggregation so that my two Mac computers can have a dual 10 GbE — or 20 GbE connection to each other across my network. Both computers have 2-port 10GbE netwo...
- Jan 05, 2022
UPDATE: got this working!
SOLUTION: Needed to create a bonded connection on the Mac side (https://www.iclarified.com/72670/how-to-set-up-ethernet-link-aggregation-on-your-mac) and also turn on LACP in the Netgear settings for each LAG. That got it working!
Jan 05, 2022Guru - Experienced User
Netgear has set up a community forum specifically for the LAN Switch products. Most of the people who watch that forum are more likely to have experience with Switch products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Smart-Plus-and-Smart-Pro-Managed/bd-p/business-smart-plus-click-swi...
Thank you.
