APDK66
Oct 03, 2015Aspirant
Can't get GS110TP to work as simple as GS105E
For my work I have to check services going over utp links in different vlans. I used a GS105E with its mirror function. I can connect the GS105E without any vlan configuration and all traffic of doze...
- Oct 11, 2015
So I understand I can't use this switch for what I want. I need to check uplinks containing 250+ vlans.
Besides the different configuration effort each time it has a limit of 64 vlans.
I have to look for another solution.
DaneA
Oct 04, 2015NETGEAR Employee Retired
Hi APDK66,
Kindly answer the questions below:
a. What is the current firmware version of the GS110TP?
b. Have tried to reboot the GS110TP?
c. Have you tried to perform a factory reset on the GS110TP?
I look forward to your response. Welcome to the community! :smileyhappy:
DaneA
NETGEAR Community Team
APDK66
Oct 05, 2015Aspirant
Hi DaneA,
thanks for your answer,
The switch has firmware version 5.4.2.19. I did reset and do a factory reset.
The current situation under test:
- factory default setting
- link with vlan 4, 6 and 7 connected to port 1 & 2 of the switch.
no traffic passes the switch.
Arjan
- DaneAOct 05, 2015NETGEAR Employee Retired
Hi APDK66,
Here are my follow-up questions below:
a. Are ports 1 and 2 of the GS110TP connected to another switch?
b. What are the port members of VLANs 4, 6 and 7?
Kindly post a screenshot of your detailed network setup.
DaneA
